2025.8 – Patch notes
Hey there Workflowy folks, we have a bunch of nice updates for you this week. We hope you find them useful and look forward to more!
Improvements
  • Sorting now correctly recognizes dates at the start of bullets.
  • The Divider is bolder and easier to spot.
  • The Date Picker Range toggle respects your preferred week-start day.
  • Markdown paste now supports [ ] todo syntax.
  • You can now search for Dividers using is:divider .
  • Color highlighted text now exports with <mark> tags in OPML.
  • Completing a Mirrored bullet shows the satisfying completion animation.
  • Mentions no longer clutter your sidebar if you’ve turned that off in Settings.
Fixes
  • The ‘#template’ button no longer hijacks your cursor when arrowing past it.
  • You can’t Mirror or create Backlinks to the Home bullet anymore (for good reason).
  • The /template slash command now works on zoomed-in bullet titles.
  • Backlinks now behave on macOS 26.
Let us know what you think!
5 7 votes
4 Comments
Flavio
Flavio
1 year ago
Gracias Workflowy!
Carlos Rebolledo
Carlos Rebolledo
1 year ago
Excelente !!! Sería ideal ordenar de la misma manera los nodos enumerados
Gracias a todo el equipo de Workflowy
Andrew Coyne
Andrew Coyne
1 year ago
Great, but I wish we could sort by date created etc without having to manually insert dates.
Dave Roth
Dave Roth
1 year ago
Reply to  Andrew Coyne
Would it be possible to have the sort functionality also sort based on date tags at the end of bullets?
