2025.20 – Calendar Found Dates, New Themes, Mirror Improvements, and More
Your Calendar now shows matching Found Dates from anywhere in your account, making it even better for daily planning and note-taking.
Drag any Found Date to your Calendar day to move it there.
Personalization
Two fresh new themes to help you make Workflowy your own: Robot and Glass.
Mirrors
Mirrors just got a little bit more reliable and useful:
  • Mirror nodes now appear in search results even when ‘Show completed’ is turned off, making it easier to find all of your content.
  • Moving Mirrors in the search results no longer causes them to disappear.
  • Mirrors stay selected after moving a group of them, so you can keep working.
Search and Organize
  • Friendly date search. Searching for natural language dates like “Today” or “Last week” in JumpTo, MoveTo, MirrorTo, and LinkTo menus now matches their corresponding dated nodes.
  • Improved multi-select dragging on mobile. Drag and drop for multi-selected nodes is now more reliable and you can drag bullets from different indent levels under a single node, and they’ll flatten correctly as expected.
  • Board columns no longer glitch when a collaborator is editing a shared board at the same time.
  • Better nested search. Nested search now supports multiple words. For example, searching Projects > Write draft -today will match nodes containing both “Write draft” and “-today”.
4.2 5 votes
4 Comments
Tim
Tim
1 month ago
Very informative post! It’s always helpful to learn more about trusted rental companies in Milwaukee and what to look for before making a final choice. Thanks for the valuable information!
Flavio
Flavio
6 months ago
Thanks!!
David
David
6 months ago
Ah les dates, mais c’est excellent !!!
Julien Gueniat
Julien Gueniat
6 months ago
Reply to  David
Grave 🙂
