Hey there folks, we’re starting April’s updates with a big list of bug fixes and a resource to help you share Workflowy with your friends and colleagues. Let’s get right to it π
Bugs fixed (13)
- Fix top item not being included when you select upward via shift+click
- Make embedded Tweets work with the x.com domain
- Don’t break bullets order when moving down last bullets on the page
- Restore moving single item up / down via keyboard
- Fix inability to switch between themes in some elusive circumstances
- Stop showing false failure error when downloading in mobile apps
- Restore downloading on Android <= 10, where it was actually broken
- Make Back & Forward mouse buttons work in the desktop apps
- Add the “Bullet” option into the multi-select menu
- Prevent code self-overlapping in the auth emails on thin screens
- Fix inability to drop items into empty columns in some circumstances
- All fonts are now available on iOS, when they should be π
- When you print 2+ pages via browser menu, all bullets are visible now
Spread the good word
We’d also like to take this opportunity to ask you to share Workflowy with your friends and colleagues. Your recommendation is the most powerful channel we have for spreading the good word of Workflowy.
Reaching more users helps us grow and influences how fast we can provide additional features and improvements.
And if you’re not sure how to explain what Workflowy is, we have a ‘Basics’ page you can share with people that shows how to get started with Workflowy and also gives the step-by-step instructions. https://workflowy.com/basics/
Let us know what you think in the comments below.
Until the next one!
Help please! Workflowy Remains in Front of Other Applications on MacOS
I want to use the desktop app but I’m encountering an issue with the Workflowy app on macOS. When I click on another application while Workflowy is open, it doesn’t move to the back as expected but remains in front of other apps. This makes multitasking very annoying, forcing me to manually minimize or close Workflowy.I’ve tried restarting my Mac and reinstalling the app twice, but the problem persists. I want to be able to switch between apps quickly
Thanks for the update. Unfortunately this bug fix has introduced a new bug, being that the toolbar buttons are now invisible using the Vintage theme. Also for Wood & Steel themes but I just assume nobody uses them π
Thanks for all of the bug fixes! Also, the WorkFlowy Basics page is excellent and just what I have been looking for to introduce WorkFlowy to others!
Also, I’m loving the pace at which you and the team are releasing bug fixes and feature updates!
Sorry to disturb; this has been going for weeks… the CMD+K menu is a bit off… installed, reinstalled, tried different browsers, etc. it’s still present… doesn’t look right to me…
This is the “OLD” / normal one (IMHO) anyway…
OFF ???
No me habΓa dado cuenta de esto porque funciona, pero serΓa bueno que se corrija.
Any chance to see the date bug fixed soon ? For people using date in a format that is non-US, the search through backling is inconsistent… and it’s really anoying :/
The bug is known
for having used Roam Research, Obsidian, Logseq, Workflowy remains the best outliner note-taking application… Simple and powerful at the same time..
Agree on it. Why do Tana, Roam Research, Obsidian, and Logseq get all that hype and Workflowy is so much ignored in the Knowledge Management world and PKM influencers?
