This is a guest blog post by Brent Kimber. If you’d like to contribute a guest blog post of your own, just email your idea to blog@workflowy.com
WorkFlowy’s tagging feature is great for categorizing things, but the search engine is really powerful too. Here’s how you can use it for some super flexible prioritization.
I’ve started marking my To Do items with a simple * (star). A search by * brings up all of my To Do items wherever they are in my outlines. This good tip is made better when I started using *, **, ***, and ******** (any amoutn of *s really) for denoting priority.
Try it, Seeing is believing. It is amazing to watch your To Do list quickly focus onto your top priorities simply by typing * then * then * again in the search box. Each successive * whittles the list down to the most important tasks. Sometimes I will add enough *s to the remaining items until only my top 3 tasks show. It’s magical. It sounds simplistic just reading but it is awesome to see the less important tasks “disappear” off of the page with each additional * typed. It’s a fantastic short cut.
Commentary from Steve, WorkFlowy’s Semi-Official Blogger: You can prepend another character for the KIND of
to-do – business, personal, house maint, etc. So, maybe H*** stands for “House, super important” and H* is “House, not important”.
I will clarify that I typically use the asterisk before the sentence un like the image in the post. It looks and feels like bullet points and has the same searching goodness.
@nhowden: It is not. It is by intention that WorkFlowy does always start to search from the beginning of a word — making it much more responsive. That’s the reason, why you should surround the asterisks with spaces.
[…] that sense, this useful tip is reminiscent of a guest post by Brent Kimber, who shared how he uses asterisks for […]
This is a great tip – however, the search doesn’t seem to work reliably without spaces. For example if I have a task “buy milk***” then search for ***, it does not show up in the search results (which I believe it should). I would say this is a bug – what do you think?
[…] comes the clever part, which I got from this WorkFlowy blog post. I can now use Workflowy’s powerful search to look for ***, and it will just show me the […]
[…] I’ll probably introduce a four-asterisk category for pages I’m having trouble understanding. Now comes the clever part, which I got fromHow to Use * and ** and ******* for Prioritization Awesomeness. […]
I think this has solved a dilemma I’ve had ever since I started using Workflowy to do pretty much everything.
I like to put each of my To Do items inside its topic area (or subtopic, or subsubtopic…), because that’s where I am when I think of it, and because when I go to act on it all the helpful context for it is right there. But I also need to see what all my high-priority To Dos are, and I’m not going to go and work on every topic area every day.
I’ve been putting all my To Dos in a separate list because I didn’t know of a better way. Now I do! The weird thing is that I occasionally used this same approach on occasion (well, !!! instead of ***, and at the beginning of the item instead of the end, but same thing) — but that was pre-Workflowy. Thanks, Brent!!!
This really improved my ability to prioritize, so thank you. I have a concern though – I’d like to be able to view “one star” or “two star” items *without* seeing my “four” and “five star” items. For instance, if I just went through “five” and “four” and only want to see “three,” it gets quite crowded since a search for “***” includes everything with “****” and “*****”.
I think I recall it used to be that if you put a space after you search, it treated it as a word and removed the wildcard appendix, so a search for “***” (3) would include “****” (4) but a search for “*** ” (3 plus a space) would not.
Was this functionality removed? Any way around it?
Did you include the quotation marks in your search string? Somewhere I read that a search for *** would hit on ****, but a search for “***” would not.
Oops, putting it in quotes doesn’t work as I supposed. You can search for *** -**** (3 *s, but not 4). Then you can star (like) the result to use the search in the future.
That worked! Thanks!!
yes!
i figured something out: allways put spaces arround the stars. e.g.:
[make me a nice warm cup of coffee **** ]
see that little space at the end? – that’s the trick.
now search for ” **** ” (with quotation marks and these two little spaces!) and here we go, you get all items with exactly four stars.
Hey guys, just switched to asterisks, great idea! Is there any advantage to prefixing the hash tag? (ie. #* and #***) such as faster indexing/searching, etc.?
Oh my! This is awesome tip!
just SIMPLY great!
Great idea…but does not work on Android.
For GTD, this would work great to have all projects as * , with each related task with at least two or more * according to priority.
Any tips to get this to work on mobile version?
It works fine for me on Android, both in Chrome and in the Workflowy app “Workflowy Agent PRO”.
Something similar to aid in prioritization is to use the tags #1 – #9 … this works, although searching for * will all occurrences of the * as shown above … searching for “*” still returned the ****** item …. whereas #2 will only return priority 2 items. Though #1 and #10 … will both return if you search for #1 …. thus I suggested 1 – 9.
Great point. I noticed the discrepancy with retrieving multiple *’s too. Might try the #1 – 9 instead
As far as I can tell, #1 is not a “legal” tag in WF, nor any other single digit. “#1-” is legal, though.
Brilliant idea! I’m using it now – super
This is great and will add it to my tools.
I use a date tag for time sensitive tasks and meetings. For example: #20140128 Meeting with Bob about system numbers.
Then when I search I can search on #20140128 for today’s tasks or #201401 for the month’s tasks or #2014 for the year’s tasks. You can almost search by week by searching for #2014012 but month is close enough for me.
I use “#due 20140401” so keeping the number of tags under control, but still making a searchable string, Can also then have “#completed 20140401”. For repeating tasks use “#repeat annual #due 20140818” , replace “annual” with monthly, weekly etc.
Best tip ever. My daily routine consists of flagging stuff I need to get done for the day. I used to add a #hot tag to each item, now I just add an asterisk. Brilliant.
Great idea – using it to create my day job list. VERY effective. Don’t forget to put a space between the word and the asterisk. Otherwise the search doesn’t find it.
Also, these might be of use here:
★☆,☻☺, ☼☾, ☎☏, ☐☑ ✉≈✔♦♫✈☠☯¼,½, ¾
Although, I’m sure using them is not exactly a best practice for scalability, maintenance, or server side escaping changes, etc. Some of them have a nice binary “state” you might find useful. Just in case my comment gets filtered, you can search the web for miscellaneous characters, geometric shapes, etc and get some useful results.
The ! !! !!! Would feel more natural
This is absolutely brilliant! Thanks for the tip!
Great idea! Works with most other characters too of course, such as ! $ % … but * is easy access if you have a number pad. I’m considering ` [ \ simply because they’re so easy to get to on the keyboard – no shifting/alting required. These other keys could work for other contexts too, if you can remember them.
On a somewhat related note, I’d love to see a search-and-replace capability (and rename tags), then I’d be less hesitant to try out great ideas like this one.
Yeah, search and replace would definitely be a good idea.
will give this a try! thanks
Good idea. Will check it out, Though current system with #today and etc… works good too!
Nice! I have been using tags like #p1 #p2 #p3 and so on. To search I need to do “#p1 OR #p2”. I’ll try this system out as it’s easier to search.
I do the same
Awesome idea! I can really use this prioritization for my GTD setup. This blog is getting better with the minute!
I love it! Simple, and great. I have toyed with this some in the past, and liked but somehow forgot it. Will be implementing more fully now. Much easier than the way I’ve been doing it.
Using Workflowy extensively for almost the beginning but this is a nice simple trick.
Your idea is great. Thanks for sharing it!
Nice tip, thanks!
Hah! such a no-brainer tip. Thanks! I WILL be using this
