#tags and @tags in WorkFlowy
You can now add #tags and @tags to your WorkFlowy document. This makes organizing things much easier, especially when your WorkFlowy document starts to get large. Type “#” before any word, like “#loveit” and then when you click on that tag, it will display only items containing that tag. Click the tag again, and it’ll remove the search.
Want some suggestions on how to use tags? Here you go:
  • When will you do stuff? Use #now for stuff you want to do today, and #soon for stuff you want to do in the next week or so.
  • Who’s doing what? Use @Name tags to keep track of who’s doing what.
  • What’s the priority? Use #important for things that will make a big difference and #urgent for stuff that’s time sensitive.
  • How long will this take? Use #small, #medium and #large to keep track of the size of the things you’re working on.
5 2 votes
18 Comments
Inline Feedbacks
View all comments
Darryl Wright
Darryl Wright
4 years ago
Are the @ and # functionally the same thing?
Rodolfo Lopez
Admin
4 years ago
Reply to  Darryl Wright
Hi Darryl, right now yes – they’re functionally the same thing.
Nanda
Nanda
10 years ago
A very useful feature.
Joe M.
10 years ago
How do I get rid of tags from the memorized tag list?
Jesse Patel
Jesse Patel
10 years ago
Reply to  Joe M.
You have to remove them from the whole document, unfortunately. If you’ve tried this, make sure you have completed items visible.
el
el
10 years ago
Would be great if tags could be renamed (like find and replace) instead of having to change each one individually
Timo Haukilahti
10 years ago
Tagging full names of persons seem to be more handy if spaces are left away. Like @JohnSmith or @TimoHaukilahti.
gwelkind
11 years ago
Google Calender integration would be superb here. For example #dueTomorrow or #due05-04-2015, could automatically create a gCal event. Adding #remindme or other attributes could add an email reminder while #important might change the color to red. Is this project Open Source? I would be happy to help implement this feature. I just began using WorkFlowy today; I have to say, I’m quite endeared. Simple+elegant, bravo.
kimn
10 years ago
Reply to  gwelkind
YES!!! Ical integration too
for those of us who refuse to be indoctrinated by the Big G;
not sure Big A is much better…
just a personal preference 😉
kimn
10 years ago
Reply to  gwelkind
Ical integration as well, please
NoOne Specific
NoOne Specific
11 years ago
A standardized syntax might be as simple as:
@Any Person’s Name
#Tag for anything else. Thought. Place. Whatever
! or #! For an immediate action required type priority
Any thoughts?
John Seiffer
11 years ago
On my Windows PC when I’m entering an item and type # or @ a list of all the related tags shows up so I can pick one. This helps me keep misspelled tags to a minimum. But that same thing doesn’t work on my phone in the android version. Is that just a limitation of android or is there a way to make that work on my phone too?
e
e
11 years ago
I was using a “!” for priority items. I tried changing them to “#!” to see how this feature would change things, but discovered that the characters following the “#” couldn’t be “!”. Then I realized that all this feature is doing is using the preexisting Search function. I don’t mind just typing “!” in Search, so I’m going back to that.
Frank
11 years ago
Same here, I heard nothing, but I got the just of it. Good Stuff.
sanjay
sanjay
11 years ago
read the article. useful. could not hear the comments from the speaker, may be something wrong with the browser.
Anonymous
Anonymous
10 years ago
Reply to  sanjay
Maybe no audio was intended. I think the video itself explained the usage adequately.
point055andrew capey
11 years ago
Extend the range of tags, to show location & type of work e.g. #atHome #atInternet #atShop #atGarden #atHol #atPC #atPhone
& #doBuy #doWrite #doRead #doChange #doChase #doDelegate #doDesign #doDo #doEscalate #doFind #doGet #doMake #doRemove #doResearch #doSchedule #doShare #doTalk
Joe T.
Joe T.
11 years ago
Just a tiny point to your examples. All the “at so-and-so place” tags, like #atPhone and #atGarden would seem better suited to use the “@” alternative, e.g., @Phone and @Garden (assuming you’re like me and pronounce the “@” sign as “at”).
