140+ Background Colors for Your WorkFlowy Lists
blog-book-buttonA couple of moons back I came out with a post on the Workflowy Re-Painter style which allowed us to tweak Painter for WorkFlowy’s 17 punch-you-in-the-face colors and tone them down (or choose your own colors).
But what this didn’t allow is for us to get background colors for lists in any browser… and we couldn’t create our own tailor-made tag names for whatever color we chose. Now the palette of every color under the sun is up for grabs – in the browser of your choice… and you can name your tags whatever you want. These 143 color tags are just a starting point:
Once you’ve added the list of tags to your WorkFlowy (I’ve got a shared list for you) – not only will you have a catalog of real-name colors to cherry pick from – as pictured above – but they will also show up in the tag autocomplete doohickey:
Use this a lot or use this a little – it’s quite something to have the background color you want when you want it, with the tag name you want. The setup is a piece of cake… and those details you’ll find in this shared list:
Click here!
4.3 4 votes
13 Comments
Alexandr
Alexandr
2 years ago
oh my friend! I’m so grateful to you. After reinstall of windows – i’ve lost this feature. Fortunately you’ve added script text. Many thanks !
landofbliss
landofbliss
8 years ago
Tampermonkey 4.5.5661 on Safari 11.0.2 won’t load StylishTag zip file. “Can’t parse!”
jftb
jftb
8 years ago
Reply to  landofbliss
Me neither — same version of Tampermonkey and Safari as above.
Overcome Procrastination by Breaking Down Your (GTD) Next Actions in WorkFlowy – WorkFlowy
8 years ago
[…] For list background colors, refer to this WorkFlowy blog post. […]
Do it Tomorrow – Yes, Really! – WorkFlowy
8 years ago
[…] list background colors, refer to this WorkFlowy blog post I came out with a short while […]
avishek kedia
avishek kedia
9 years ago
Will this work on Windows 10 edge browser Frank?
9 years ago
Reply to  avishek kedia
Hi. You’ll have to look into whether the Stylish extension and the Tampermonkey extension are supported in the edge browser.
Looks like Tampermonkey is supported:
https://tampermonkey.net/?browser=edge
… but it doesn’t seem like Stylish will work in the edge browser:
https://forum.userstyles.org/discussion/50800/stylish-for-microsoft-edge
There may be a way to run CSS with Tampermonkey… you’d have to look into it.
sashalahrs
sashalahrs
9 years ago
Frank, how can you change a color once one line is colorized? I remove the tag and it still retains the original color? Do we need to delete the item entirely?
9 years ago
Reply to  sashalahrs
Hey Sasha, you probably have the original “Painter for WorkFlowy” extension running. If not, that’s quite an interesting scenario. Have you tried refreshing your tab?
Also, remember that the tag is set to be transparent… maybe you could try Alt-Clicking on the tag to explode it…
Mike Zobrest
Mike Zobrest
9 years ago
No luck on Chrome.
Mike Zobrest
Mike Zobrest
9 years ago
Reply to  Mike Zobrest
Ooops, Sylish was off, winning!
9 years ago
Winning with at least a handful of colors that you might fancy 🙂
9 years ago
BONUS: once installed, try the #blink or @blink tag, additional to whatever background color tag you’ve got going… and see what happens 🙂
