3 Markedly Different Dynamics to Color Code your WorkFlowy Tasks
Last year August I came out with a post on “140+ Background Colors for Your WorkFlowy Lists“. Since then I’ve refined the style quite a bit… AND added to the repertoire by putting together 2 additional styles. Both are solutions which are a lot more minimalist – and you can still cherry pick from over 140 colors.
Compare each of the 3 dynamics:
123
… And here’s a video to show you the moving parts:
The above screencast is part of Module 3 – “A Facelift For Your Brain” – at the WorkFlowy Academy, which offers a host of ready-to-install templates that tweak every element imaginable in WorkFlowy – with both aesthetic and practical dynamics.
Here are a few more screencasts from Module 3 which I’ve made public.  And also… you’re welcome to subscribe to the WorkFlowy Academy YouTube channel.
Now to color your world… responsibly 🙂
13 Comments
Patricia
Patricia
2 years ago
Coloured bullets are no longer showing on my PC 🙁 What happened?
Tim H.
Tim H.
5 years ago
Hi Frank, everything works, thanks… But I can’t figure out how to remove the color tags and get back to a bullet with normal lay-out.
Also, I would like to have invisible bullets so that I can get (white) line spacing between different nodes. – That’s the one thing that really bothers me in Workflowy – you can not set groups of content apart from each other.
Is there a way you can do that with all your css magic?
Unfortunately I don’t have any IT skills, so I can not figure it out by myself. 🙁
daviddoherty02
daviddoherty02
8 years ago
Frank,
This looks great in my Chome desktop browser, but how to you see color-coded tags on the mobile app?
Thanks
David
Frank Sanford
Frank Sanford
8 years ago
Reply to  daviddoherty02
So was using Workflowy as a crocery shopping list at the store and as I was deleting an item by swiping to the right, a solid green line appeared that I can’t seem to delte?
Frank Sanford
Frank Sanford
8 years ago
Accidently placed a green color line across the screen. How do I delete?
Maria
Maria
8 years ago
Hey, Frank! I have a question unrelated to this post but comments are closed on that one. Did the “mother lode Unicode list” go away? It used to be here: http://snip.ly/5h80d
Hector 🅰️ Parayuelos (@hecpara)
8 years ago
I’m excited to get this started, but I’m getting the same “Can’t parse!” error on Chrome Version 66.0.3359.181 (Official Build) (64-bit) that some folks were commenting on, on the previous post you referenced. Any thoughts?
8 years ago
Disregard – I was trying to import a file, not a zip. Unfortunately I am unable to delete the comment above.
8 years ago
I’m running into an issue – due to the behavior of the script and how it blanks out the color tag itself by turning it into a circle, when I move the cursor to the end of the line and press ENTER to create a new line, it just moves the color tag to the new line. Any way around this?
8 years ago
Try hitting your Down arrow before hitting Enter… Incidentally, this is a cure-all for starting a new list below your current list – no matter where your cursor is in the current list 🙂
John Hubbard
John Hubbard
8 years ago
The #colors show up on mobile now.
johnwin
johnwin
8 years ago
Frank – brilliant! Thank you so much for this massive upgrade.
8 years ago
Reply to  johnwin
You’re welcome John 🙂
